FF10 in Amerika und Europa identisch?
    You HK receiver will most likely have another region code on it though. Unless they are selling EU regions codes, then you will be okay. I ma not 100% sure about this but it is what I read lately.
      Hi John,
      ich habe auch eine "deutsche" /:=| TG12 mit CE-Label und 608 und 6014 aus Hong Kong. Works fine, saves bucks
      Nur der TX muss ein CE-Label haben, weil er sendet. Ein RX brauch kein CE-Label weil er nur empfängt.
        I havenn't tried it yet but this is what I believe (not sure but it sounds technically likely) :
        -FASST receivers can operate worldwide, they are not region locked as FASST TX modules are.
        -FASST receivers learn the ID from the sender when you bind it (button), they have not a region coded ID which is involved in the demodulation procedure
        -The problem with the T6 FASST having the ID=0 ttends to show that every FASST receiver worldwide can operate with the same sender ID whatever the region is (ID=0 is not even a true authorized ID)
        -FASST frequency shift keying (or frequency hopping spread spectrum to be more accurate) is sender driven, the receiver has to "follow". Modulation and frenquencies used are the same worldwide (b ut the FRANCE mode restriction which do not use the upper half of the band)
        -TX FASST modules are region locked, they operate only with sender from the same region. All European modules CAN perform the FRANCE restriction, so we MUST use them, then we have to get a European sender naturally.
        I will test it as soon it reach my house. I will tell you if it works but I am confident enough.
        Thomas
        EDIT: JMalberg has tested, now I am sure that I didn't buy a dead box
          Hi Thomas,
          this is an original Futaba Product, and those have also completely strict guidelines.
          otherwise they might not sell their products worldwide.
          it is subject only to the countries, a CE examination through supplies and these by it to mark.
          if you fasten and again remove the receiver sometime with tape, is the CE sticker also with away
          I use 4x 608er and 5x 617er Receivers from the USA,
          as well as 4x 608er, 7x 617er and 3x 6014er from Germany,
          I noticed no differences or any problems !
          Steven / Big Papa
            Zitat von JMalberg
            Hi John,
            Cool, ich hatte nur false gelesen. Aber mit Futaba 10C von den USA, wurde dass auch gehen mit ein Deutsche RX oder von Hong Kong?
              T-10/FF-10 arbeitet auch mit Modulen von Fremdherstellern wie ASSAN zusammen. Absolut null Problem! Ich machte gestern den Test bei einem befreundeten Piloten. Der hat eine FF-9 und das Modul von ASSAN passt exakt und funktioniert auch bestens. Nachdem ich bis vor kurzem noch FF-9 geflogen bin und leider alles von ASSAN verkauft habe, ordere ich nun wieder ASSAN Equipment da ich damit äußerst zufrieden war. Zum Preis von einem RF-6014 Empfänger bekommt man 4 Stk. ASSAN 7 Kanalempfänger plus HF-Modul und das finde ich cool!
              Nur soviel zum Statement dass die neuen Futabas nur mit Europa-zertifizierten Modulen arbeitet. Das wäre für mich ein Schock gewesen!
              Übrigens, das Original 2,4 Ghz TM-10 HF-Modul hat ein kleine aber feine Änderung gegenüber den etwas älteren TM-9/8 Modulen (welche jedoch allesamt passen). Nämlich die digitale und damit erheblich flottere Übertragung des Signals! Diese erfolgt offenbar durch einen kleinen Stecker, seitlich des HF-Moduls. Dennoch funktionieren auch die alten HF-Module der FF-9. Das finde ich sehr praktisch!
              Jetzt wissen wir es also besser und ich danke den Mannen von Futaba für die gnädige Nachsicht und die Möglichkeit auch anderes, wesentlich günstigeres Equipment zu verwenden
              Gruß Heinz
