The FX36 add more switches
  • The FX36 add more switches
    Hello Sir ,
    I have buy a FX36 for my construction crane RC model.
    if want add more the switch on the FX 36 for my RC model use .
    how do I connect these switch wires?
    I have try open the back cover . only find two connector SI and SJ .
    I plan use the SI and SJ for the stick switch with 3-pos and push button switch I just order from RC technik .
    Because there are only two connectors
    If I have more switches installed, how do I connect these switch wires?
    please try help me thanks,
    Thank you ,
    Best Regards,
    ChihMing Chou
    Hello,
    There are still two cables with plug for SF and SC available.
    With SI and SJ four additional switches are possible
    greeting
    Alfred
      Zitat von Alfredo_3 Beitrag anzeigen
      Hello,
      greeting
      Alfred
      Thank you.
      I think your mean are the two cables of the F/H and A/C . Thanks.
      but I just think about the several other reserved locations, if I have more switch installed .
      Where can I have a socket?
      Thank you ,
      Best Regards,
      ChihMing Chou
        Hi ChihMing Chou
        yes, I meant these cables.
        I think that with 10 switches, this is the end of the FX 36.
        The case of the FX 36 is taken over as a desk transmitter from an older series. Since you could install a "multi-switch module".
        greeting
        Alfred
          Hi ChihMing Chou
          greeting
          Alfred
          Hello Sir,
          Many thank you for this reply .
          I just check the internet have many type of the "multi-switch module".
          Can you recommend or suggest ...which one is recommended for use in FX-36.
          because I am from Asia , very few like this data info can reference .
          my email address:choucm@ms4.hinet.net
          If you don't mind, I hope I can contact you by mail.
          Thank you ,
          Best Regards,
          ChihMing Chou
