Hello,
I'm sorry about the language but I've found an annoying bug in the FX-32 firmwares. It's present in the latest 1.7 version as well as in the last non LBT version 1.3.
The problem is that I can't enter negative values to the mixer fine tuning option, if I try dial below zero, the value jumps to +255 and next step is +100. This is specially annoying with the ATL+ or ATL- option because I can't reduce mixer values and in effect prevents the use of alternating mixer rates with two opposite mixers.
In the FX-30 and 18SZ negative values can be entered and the mixer fine tuning works exactly as supposed.
Sent the same message to Ripmax but got an automatic response that they are closed due to Covid 19 since March, then sent the same message to the ACT-Europe.
Regards, Harri Pihl
Regards, Harri Pihl
