FX 32 - Free Mixer - Fine tuning - Negative rates - do not work
  • FX 32 - Free Mixer - Fine tuning - Negative rates - do not work
    Hi all,
    Sorry for adressing to you in English,
    (I can read German however)
    I came across a bug in my FX32 V1.2
    Under the option (I changed my setting to german to get the correct naming)
    PROGR-MIXER
    Pagina 2
    FEIN-TRIM / RATE (%)
    If you change the fine trim down to 0 and then one step further down it jumps to 255 and then to 100 again.
    I would like to apply a negtive value here.
    My FX-30 V1.6 can do that.
    I assume it is a bug. Can someone affirm this is also the case with the later versions.
    Or is it fixed in later versions?
    Thanks for your input.
    Regards,
    Hans
